Satin Hood
alidav
Satin Hood
Post by alidav »
Hi
can anyone help me please. I would love to purchase a double layered satin hood but cannot find one. Failing that is there anyone out there who can make them.
Just love the tight feeling of satin over my face
david
seasideshow
Re: Satin Hood
Post by seasideshow »
Hi, I like satin hoods as well, the only way to get a double sided hood is to make it yourself. They are dead easy to make, you can machine or hand sew them, make them from either new material or from a satin dress. Try making it safety pinned together to get the right fit then sew it up, you only have one seam to do and if you make a cock up of the job just pick it out and have another go. I find the thicker heavier satins feel better, I make the top of the hood rounded because it makes for a more snug fit across the face. Hope this info helps you.
