Satin Pussy
nightie071090
Re: Satin Pussy
Post by nightie071090 »
Love that idea!
satynowyswiat
Re: Satin Pussy
Post by satynowyswiat »
redstn wrote: Thu Oct 30, 2025 8:48 pm I found a fun new way to fuck satin! Its simple and the result is a tight satin pussy, it feels so close to the real thing. All you need is a satin blouse and a long satin hair curler, I got mine from kitsch, they make a really long one that helps this technique a lot. Next you will coil up the hair curler.IMG_0792.jpeg Then turn one of the sleeves from the satin blouse inside out and push it through the coil, and from there you fold the blouse sleeve back around the coil and then push the whole thing back through the arm hole. IMG_0793.jpegAnd there you have it, an all satin pussy, you can also stuff a nightie or a sheet into the hole to make cleanup a little easier.IMG_0795.jpeg
You're a genius. I'm going to buy one tomorrow.
Satinstuff
Re: Satin Pussy
Post by Satinstuff »
I have purchased 2 of this and will be trying out this method, you are a genius.
I’m using another method with plastic cylinder hard sleeve and I folded the front panel of the dress into the insert and made it into a fleshlight. It works for almost all the structured satin sheath dresses though some dresses require larger or smaller diameter sleeves.
Satinstuff
Re: Satin Pussy
I’ve advertised my dresses for strangers to use them as masturbators and one of them tried this piece and needless to say, he was addicted to the sensation and he’s been nutting into it close to a month. My game was simple, use my dress to edge instead of his hands so he’ll eliminate the need for line and messy cleanups, he did just that but could hold himself, ended up filling the insides with his love juice.
Jags1088
Re: Satin Pussy
Post by Jags1088 »
Althogh good idea. I read dry humping is bad for penis
