Hot weather
SatinDeejay
Hot weather
It’s a relief that heatwave has gone so I can get back in my satin pyjamas as nighttime
satynowyswiat
Re: Hot weather
Satin pijamas are the best even in that heatwaves
- TomThompson
Re: Hot weather
If you have to lie naked under something, a satin sheet is hard to beat. Just try to be very still so that the satin doesn't start to slide on your cock or nipples - therein lies the path to heat being generated!
SatinDeejay
Re: Hot weather
What do people do in the summer? I love wearing my long sleeve satin pyjamas in bed but I get sweaty in the night
satinsheetlover
Re: Hot weather
I have 25 momme silk pajamas , as does my wife. We also have 22 momme silk sheets. They definitely keep you cooler in the heat- and horny! We swap the satin for them when it gets too hot. Way too expensive but worth it!!!
satynowyswiat
Re: Hot weather
Thats true satin is the Best for all time. Its dry faster and you Can clean it faster no matter that its dirty sweaty or cummed.satinsheetlover wrote: Tue Jul 26, 2022 11:44 am I have 25 momme silk pajamas , as does my wife. We also have 22 momme silk sheets. They definitely keep you cooler in the heat- and horny! We swap the satin for them when it gets too hot. Way too expensive but worth it!!!
