Satin bedsheets
Silksatinfetish
Satin bedsheets
Hi am wondering if I can wash black satin and turquoise sheets together thanks
MrsSatinblouse
- Contact:
Re: Satin bedsheets
Best not as the colours might run and ruin the turquoise set. might be ok on a cold wash but it depends if you are willing to risk dying them
Silksatinfetish
Re: Satin bedsheets
Thank you abit late now as I've washed both togetherMrsSatinblouse wrote: Tue Jan 18, 2022 8:13 pm Best not as the colours might run and ruin the turquoise set. might be ok on a cold wash but it depends if you are willing to risk dying them
Re: Satin bedsheets
Hi,
It is best to wash them separately other wise the color will fade,
if possible use separately and use tumble dry.
