High Quality Satin Fabric
SatinTom
Post by SatinTom »
Hi everyone,
Can anyone recommend a company in the EU that sells high quality satin fabric ideally wholesale? If they know there satin well and had various types is Charmeuse, Bridal etc it would be brilliant. Idealy I'm looking for the best machine washable satin fabric that I can get.
If anyone can share the technical details (thread count, best use etc) of the different types of satin I would appreciate it.
Thanks 😀
GOWNRAPER
Re: High Quality Satin Fabric
Post by GOWNRAPER »
Hi SatinTom
There is a company in Berlin that sells a good quality satin
The fabric is called Watusso Como satin.
It starts at just over £26 per metre and has some stretch in it
They can supply you with all the tech details on weight etc
Have bought a few gowns made from this fabric which I find
very enjoyable and can hand or machine wash at 40C (do not exceed)
Hope this helps you find what you are looking for
GOWNRAPER
SatinTom
Post by SatinTom »
GOWNRAPER wrote: Tue Feb 26, 2019 8:34 pm Hi SatinTom
GOWNRAPER
Excellent, thank you. I'll look into it.
SatinTom
Post by SatinTom »
Bump. If anyone has any links or company names please let me know.
Thanks!
