Using a vibrator with satin for a great wank
Try using the magic wand with your cock encased in satin.
Re: Using a vibrator with satin for a great wank
Can you recommend a nice wand massager? I've seen some cheaper 'clones' on eBay for around £15 and was wondering what they are like compared to the branded ones.
The Magic Wand is not cheap, about $130 but it is powerful and durable. You can use it with a slide lamp switch to get variable vibrations.
Thank you. I found this site with some tips/recommendations for guys on how to use these wand massagers. Interesting reading!rder1913 wrote: Fri Mar 02, 2018 7:38 pm The Magic Wand is not cheap, about $130 but it is powerful and durable. You can use it with a slide lamp switch to get variable vibrations.
https://thebiggayreview.com/gay-mans-gu ... massagers/
