Uploading smaller file sizes?
TheWatcher
Post by TheWatcher »
Hi I'm on an iPad and every time I try uploading a pic it's says the image size is too big, is there an app anyone knows of that makes the file size smaller?
SatinLush
Re: Uploading smaller file sizes?
Post by SatinLush »
1. Launch Image Size from your Home screen.
2.Tap the Image Icon in the upper right corner. ...
3. Tap the image you would like to resize.
4. Tap Choose in the lower right corner.
5.Select your image resize option at the top of the page.
See if this helps
