Anyway, I tried satin humping (dry) last night, diddnt like it. However I then got one of my girlfriends satin dressing gowns and wrapped it over a pillow so it felt like a torso. I then lay down in bed and placed it on top of my chest lengthway, mimicking as if she was lying on top of me.... F**k me it was awesome! Best satin wank I ever had! Anyone else tried this? It truly was an experience I'll never forget, and will be definitely repeating!!!
Satin humping
Satinseduction
Satin humping
There was a similar thread on this topic on here before but can't find it, so here is a new one!
Re: Satin humping
Yes I've tried the same thing with a satin chemise while wearing another myself. Plus satin sheets for good measure. It felt so good with the layers of satin gliding against each other. I know it's a bit sad and it would be better with the real thing on top of me but still, it was really nice
Satinseduction
Re: Satin humping
I do get the real thing, but we've come to a compromise now where every other time we have sex its satin sex, normal naked sex in between. Think she thought satin was taking over, so now the compromise is:
Satin sex
Normal sex
Satin sex
Normal sex
... In a repeating pattern
Satin sex
Normal sex
Satin sex
Normal sex
Satindestroyer
Re: Satin humping
I love to use a pillow as well, I wrap my moms coats around the pillow then I hump it naked and mimic some sex positions. Then I blast a huge load on top of it
SatinLoveJJ
Re: Satin humping
I do A LOT of satin humping. I have since I was really young. I've got quite a big selection of satin night wraps, satin pyjama sets and some blouses. Putting them over a duvet rolled up with a pillow on top adds a big of firmness, almost as if you were humping your girlfriend's leg.
It's been a while since I've had chance to wash them though as it's a bit strange trying to wash about 20+ satin items with cum all over them, when you're living with your fiancee's parents
SatinSilkMatt
Re: Satin humping
Satin humping is amazing! Every satin play session that I have always involves my satin covered bed of course, just whether I'm inbetween the sheets or on top of them is the difference. I usually start off laying down a flat/top satin sheet over my body pillow (thank you Bed Bath and Beyond ;p), which, if itself of course is in a satin pillow case as well. Then while I wearing a satin robe I mount the satin covered body pillow and just start grinding my cock against the layers of satin; I throw another satin nighty/sheet over my cock so it's sandwiched in against the pillow and I then proceed to grind and hump it in various positions. I often times finish like this and cum all over the satin sheet I have layed over top of the pillow. Other times I get into my satin sheets and hump my satin comforter and use various satin garments and depending on which garment I'm using I either cum right onto it, with it, or with it and into a condom so there's not as much of a mess/cleanup!
