Satin in winter
soochasatin
Satin in winter
Post by soochasatin »
I 've had a satin quilt cover and a satin bed sheet in August this year. I fully enjoyed it covered completely in satin fabric and specially went crazy changing sides in that quilt. Most often I got wet in this situation. But as weather has turned cool so now it s difficult to go with that thing. I 've replaced the satin quilt with a cotton covered quilt but the sheet exists to this day. What advice can you offer to go with my satin quilt in this cold winter
davidben
Re: Satin in winter
Post by davidben »
It sounds as if you have really grown to enjoy your satin quilt cover during the summer.
I agrees that it is now a bit cold getting into satin sheets this time of the year.
Might I suggest that you continue to enjoy your satin cover by filling it length ways with pillows and then rolling it up into a sausage shape and hold it next to you in bed. You may also like to rub it between your legs for pleasure and also keep you warm.
It certainly works for me !
D
GOWNRAPER
Re: Satin in winter
Post by GOWNRAPER »
As I NEVER close my bedroom windows,I do on
occasion use an electric underblanket set to MIN setting
just to take the cold shock when entering the bed
Try this method(make sure you switch off when you get in)
You may like it warmer so try a higher setting till your happy
with the result
I do prefer cool satin to play with as it stimulates me more
than hot satin,having tried all settings. Give it a go
They are quite cheap to buy
