Forum User Guide
satinforum
- Site Admin
Forum User Guide
This forum is currently running a version of phpBB.
If you are unfamiliar with using phpBB it may be useful to refer to the user guide which is available to read here: https://www.phpbb.com/support/docs/en/3.0/ug/userguide/
This covers such things as:
- how to use private messaging (and the difference between outbox and sent box)
- how to use the friend/foe feature to highlight or block posts/messages from certain users
RodaSaTiNStein
Re: Forum User Guide
My gaming clan is using the exact forum type... have to be careful not to post on the wrong one
Even tho my clan mates know about my satin fetish
end of transmission...
Roda SaTiN Stein
Roda SaTiN Stein
satinlover2012
Hi Mod,
Just wanna know how can I change my username?
Do I have to shut this account and create another with same email id (will it work)?
Hello mods!! Great to be here. I’m having trouble with messages being sent. I have two messages I’m trying to send and their stuck in the outbox, and won’t send. Can someone please help? Thank you
Satindreamer69
Have you checked with the user whether or not they'd received them. I thought the same but they had actually received the message.maiden wrote: Thu Jan 09, 2020 4:37 pm Hello mods!! Great to be here. I’m having trouble with messages being sent. I have two messages I’m trying to send and their stuck in the outbox, and won’t send. Can someone please help? Thank you
Satindreamer69
Actually I just checked and mines the same. I have a message stuck in the outbox but can't see a button saying resend.maiden wrote: Thu Jan 09, 2020 4:37 pm Hello mods!! Great to be here. I’m having trouble with messages being sent. I have two messages I’m trying to send and their stuck in the outbox, and won’t send. Can someone please help? Thank you
Hey thanks a lot!! This is very frustrating
I tried sending you a message but it’s not leaving the outbox. I read on the FAQ that the board admins can take away the privilege of sending messages. I hope that’s not the case. Really hope I haven’t offended anybody or broken any rules on the forum. I don’t think I have
Satindreamer69
Well looks like it worked for those messages.
Hiya
My posts to threads and private messaging don't work, does anyone know why this could be?
I believe the messages stay in the outbox on your end until read by the receiver.
- SlinkyPaula
Yer I can't even get my introduction post moderated. So I'm in limbo
satinbound
Re:my pm messages
I don't know how to erase, or delete my old messages so I can read new ones. It says my box is full so I am stuck and can't read any new pms Please help. jbrandes762@gmail.com
xseekerx70
Private Messages -> Rules, folders & settings -> Folder Options -> If folder is full: Delete oldest messages
If anyone else sees an option to delete messages do let me know, the above was all I could find.
For every message in your Inbox, Sent folders etc., there's a tick box at the right hand side. Tick the message(s) you wish to delete. At the bottom of the message list on the right hand side is a box with the default option "Mark/Unmark as important". Click on the arrow box to the right of that and that brings up a selection of options with "Delete marked" as one option. Click on that, then click "Go" to the right and Voila!
It sounds more complicated than it is but you can choose which messages you want to delete and which to save.
