SatinPlay Preview
General discussion about things happening at mysatin.com & satinplay.com
Chickenboy19799
Contact:
SatinPlay Preview
Post by Chickenboy19799 »
Hi, is there any chance that you could add the free 2 pic preview to the satinplay website as you have on mysatin? Having the 4 preview pics gives a better idea of the sets and helps decide whether to join again. I have joined both sites several times so am not just a taker btw.
Thanks
mysatin
Re: SatinPlay Preview
Post by mysatin »
Thanks for your suggestion. This is something we have been considering (offering more of a per-set preview) but we aren't sure of the precise format at this stage.
mysatin
Post by mysatin »
We have started adding a video preview (screencaps) to satinplay.com to give a better idea of what is in the videos. We will see how the format works out and would welcome feedback.
For example - see http://www.satinplay.com/satin-silk-gal ... hties.html - there is a link to some screencaps from the video.
georgegt3
Post by georgegt3 »
The screencaps are way to small you can hardly see them.
Also can you send us the link to join both sites at once. Thanks
Satin always looks best on a women
test45
Contact:
Post by test45 »
Yes, the preview screencaps are good but would be better if they were larger. A couple of preview images like the ones offered for each My Satin update would be an alternative.
Favourite Models: Ruby.
Favourite Clothing: Trousers, Dressing Gowns, Salwar Kameez.
Requests: Group Shoots, Outdoors, Speech, Wet / Messy.
