need your advice
soiememe
need your advice
Post by soiememe »
I made up my mind: I'm going to order a long silk nightgown. I have been dreaming of this for ages but now I decided to give in and indulge myself with some lovely silk...
There are still 2 options: a red ankle- length gown and a white gown with round neckline.
Which one would you choose in my place?
Please let me know, I'm going to decide tomorrow.
coatfun
Re: need your advice
Post by coatfun »
I would go for the red gown first. Red satin is my favorite and is so sexy. Then I would branch out into different colors.
Keep an eye on Ebay and you can build quite a collection.
Freddielinton
Post by Freddielinton »
Red.
nigelsatin
Post by nigelsatin »
Buy both - wear one inside out underneath the other so that you get the soft shiny side against your skin, and can feel the two layers slide over each other. Heaven ...
Dreamsofdresses
Contact:
Post by Dreamsofdresses »
nigelsatin wrote:Buy both - wear one inside out underneath the other so that you get the soft shiny side against your skin, and can feel the two layers slide over each other. Heaven ...
Thats the voice of experience :)
Girls+Satin = Win
soiememe
Post by soiememe »
Thanks for the advice nigelsatin!
I only ordered the red one for now but who knows what the future brings :D
satinage
Post by satinage »
love the red one so much
Fan de Satin / Satinfan
annette
Post by annette »
Hi, Yes they are lovely! If it were my choice I would order the white one as its so femm! The red will give you more kinky erections and as mentioned if you order both and wear them together they will slip and slide so much you won't last more than 5 mintes before you find yourself tossing off!
Annette xx
