Satin sheets on Ebay? Help
satinloverboy
Post by satinloverboy »
The administrator recommended that I buy satin bed sheets on Ebay, as that is were the sheets in the videos are bought from. However there are thousands of choices. In terms of glossiness and the kind shown in the videos, which ones should I get. The shinier the better.
BTW, what type of satin sheets are used in those videos? Silk satin or Polyester satin?
Freddielinton
Re: Satin sheets on Ebay? Help
Post by Freddielinton »
Unfprtunately, the only way you'll find out is through trial & error until you find the kind you want that feels the best. There's so many different results that show up on eBay.
IReallyLovePureSilk
Post by IReallyLovePureSilk »
Well, I doubt that the administrator used pure silk satin sheets for his videos because of the expense and the special attention they deserve. I think that Freddie said it best in order to keep your options open. I'm probably going to be attempting to upload a video somewhere online of one of my pure silk satin sheets because in my opinion I feel that they look, move and feel the best and believe me, I tried to go back and forth between polyester and pure silk and I'm stuck with silk! Polyester satin has its advantages over silk. It is easier to care for, has a much shinier look and in some cases they are an almost similar to pure silk satin, though it's flowiness doesn't compare. If you can find pure 100% silk satin (also called charmeuse in most cases to change up your searches) sheets for a good price, if you're willing to give them the special care they recommend, give them a try! If you're looking to spend less, in which I believe that is what the administrator gets and would probably be better for your budget, then polyester charmeuse satin sheets would probably be a better choice for you!
How a woman should be touched...
When you drop silk on her skin, the same way that touches her and falls down at the same time... that is the perfect way to touch a woman...
satinloverboy
Can I really go by the photos of the bed sheets all set up in the advertisements? Do the actual sheets look like in the photos?
IReallyLovePureSilk
I'd ask the administrator personally what he uses if it were me. He'll give you some ideas of which ones he does buy, I'm sure.
Bollogray
Post by Bollogray »
Hi i bought satin bed sheets from ebay, from a shop called one stop bedding and i am very pleased with them hope this helps in any way.
Freddielinton
I just realized I spelled "unfortunately" wrong. I fucking hate the on-screen keyboard on my phone. The auto-correct sucks ass :lol:
satinloverboy
I tried sending a PM three days ago asking for his recommendations. He hasn't responded.
frackblogingston
Post by frackblogingston »
I'm looking for some satin sheets at the moment. I had some from Bed Bath and Beyond that were pretty nice. Wal Mart brand wasn't as nice. I'm curious if you've found any.
