How to clean jizzed-up clothes
Let's say you use dry-clean-only satins for your...pleasure. Obviously you probably don't want to take those things to a dry-cleaner. So what's the best way to clean that stuff?
Frillylover
Re: How to clean jizzed-up clothes
If it's made of polyester satin I've had good results giving my dresses a hand wash in the bathtub with a couple scoops of oxiclean, and be sure to rinse well and hang to drip dry. If there are some stubborn...umm...'marks' you can use some shout spot cleaner and let it sit a day or two before washing. This method has worked well for me even on gowns marked dry clean only. However if you're dealing with acetate satin it's generally not a good idea to try and wash it, I've gotten away with it but it tends to lose its shininess after a couple times. So those tend to be my 'do not cum on' dresses.
Fan of the frillies
