Sooo soft and silky.. Mmmm
Home alone in 10 days..
Re: Home alone in 10 days..
100% silk satin blouse
Is it posible to wash cum out from so expensive and silky fabrik??
- IReallyLovePureSilk
Depends on the silk, really. Chances are...if that silk blouse is dry clean only, which it probably is, you will definitely have a hard time getting the stain out without anyone noticing it on there. It's more hassle than you think if you don't know much about 100% silk satin. Most cleanings, including dry cleaning, might not get the stain out. Washing it will definitely make the silk look and feel different if you're using the wrong detergents. If you take it to a dry cleaner, you "cannot" take it to a cheap ass cleaner or one hour cleaner. They will further mess it up more than you know. You need to take it to a more eco friendly dry cleaner that actually knows how to clean the silk. Yes it will be more expensive but if you want great looking and feeling silk again, it has to be the professional cleaners that are able to.
It's a risk for you to cum on it without anyone noticing. I'd recommend cumming on something else that is not silk without any of it getting on the silk if you're thinking of stroking with it, which feels totally amazing BTW. I'm accustomed to cumming without getting it on my silks so I'm pretty experienced when it...cums to that! LOL I hope you find the best solution if you are contemplating on at least stroking with that silk blouse!
How a woman should be touched...
When you drop silk on her skin, the same way that touches her and falls down at the same time... that is the perfect way to touch a woman...
The first black dress I cummed on was not clean after Wash, maby I steal ita nd make a really mess out of the sexy dress?
Time to rip it??
Time to rip it??
Good gravy. You really fucked up your girlfriend's blouse good! Is that cum all from one single cumming?
About that beautiful short black dress, don't use scissors. That's no fun. Jizz all over it instead. And then find a seam and rip it from there using your own hands.
Thank you for sharing btw!!!!!
RIP Bob 6/27/1958 - 9/29/2015
X.com/CumStainDress
X.com/CumStainDress
- satinstainer
- Contact:
I have to agree with Destroy about that black dress....it's MUCH more enjoyable to rip it if you're gonna do something to it
The sight and sound of it tearing might add a bit more thrill to whatever else you do to it. Cum on it as you rip it, you might like that
As far as your girlfriend's(?) blouse....EXCELLENT soaking you gave it
Wish the lighting was a little better, but still good pics !! Does she know it's missing ?? What would she say if she seen it ?? I think you might have ruined her pretty silk blouse
Oh well.....now you'll just have to make a cum rag out of it
Poor silk blouse...shame you won't get to have her wear it while cumming on her and the blouse. I'd wonder if she'd jerk you off with it and have you cum into it if you hadn't have done that. That would be glorious IMO! Better hope she doesn't discover that or even try to look for it but that's your own risk. The real question is, did you cum while jerking off into the smooth silk or did you just lay it down and just cum standing over it? If I really wanted to cum on a silk blouse, I'd cum right into it while jerking off with it...better that way if you ask me! All I will say is this, all of that cum will not come out of the blouse.
On a more positive note though, at least you had your fun and I'm sure it was definitely worth it! How many times have you came?
Hi.
The silk blouse and the blouse i cummed is not the same blouse, the blouse I cummed over is a satin blouse, no problem to clean..
The silk blouse is to expensive. The silk blouse wil be a cum blouse in the future..
Ha! I stand corrected...though both the silk blouse and the satin one look extremely similar...why is that?
Well, at least you do have a small conscience inside you! LOL I know there are some others that would beg to differ, no offense to them, but we all know how expensive silk really is, but to me it's worth every cent! Save it for that special moment, hopefully with your girlfriend! I know I would!
ilikeitshiny
Is that one of the blouses she wore when I cum on printed pics of her a while ago?
Liking it shiny
Yes, the silk blouse ie the blouse she is wearing on the Pictures you cum my wife...
This wil be a blouse for cum and sex in the future.....
But the black dress??? I dont know,,, In one way its already destroyed,,, Let her se it,ore trash it?? RIPPED dress is one thing....
ilikeitshiny
Great! I enjoyed my cum on your wife
very sexy girl! Show her the blouse and make her wear it for more sex and cum. I want to see more of her
Liking it shiny
getther2004
- Contact:
Burn it!!!satinsilk wrote:Is this the Next step for this sexy dress??
